Noise Control
Noise Control
Noise Control
How to calculate the noise level(dbA) after install an enclosure or other acoustical insulation materials inorder to reducing noise of machine.
RE: Noise Control
You can refer to book title measuring noise level.theres are completed with method to measure and calculate the noise.you can use fiber glass to reduce a noise but you need to know first your noise level in order to design  your silenter thickness.
