Shear rate of CD Direct shear
I am going to run CD Direct shear test but I do not have data of consolidation for calculate Shear rate. Can I assume Cv from Plastic limit? Who have any suggestion?
thankyou
thankyou
RE: Shear rate of CD Direct shear
azurite opined,
it seems impractical to run a direct shear test for over an hour on any sample...
We've been doing these kinds of tests for about 50 to 60 years now. Tedious, boring, time consuming - yes. But impractical? No. Given the availability of relatively inexpensive data acquisition system (DAS) hardware and software - and dirt cheap PCs, dedicated DAS is more practical than ever. If you don't want to sit up all night taking readings, install a DAS. You can do it for less than $1,500. The payback period is pretty quick at that price -
Please see FAQ731-376 by VPL for tips on how to make the best use of Eng-Tips Fora.
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
