Duplicate Shortcut
Duplicate Shortcut
Duplicate Shortcut
Visio 2000 had a "duplicate" item when I right-click an object.  I've upgraded to Visio 2002 and it is no longer there.  Is there any way to customize the right-click menu?
Also, Visio 5 had right-click copy and paste when the text with a block was highlighted.  This disappeared in Visio 2000.  Is there any way to restore this?
I miss using the mouse for these operations -- must use keyboard shortcuts instead.
RE: Duplicate Shortcut
I need to install Visio 2000 on a new PC.  I have lost the Product Key.  I tried searching the registry on the old PC to find the Productkey.  I was not able to find the Product key in the registry.  Any suggestions?
If you have a legitimate copy, you should be able to get help from Microsoft.
TTFN
ctrl+d duplicates in Visio since version 1.0
