Editing Attributes
Editing Attributes
While at a contracting company, I was using AutoCAD 2002 and there was a setting refering to blocks I can not remember. When you double-click on a attribue in a block block, the enhanced dialog box would appear and the attribute you clicked on would be the first one you could edit, instead of starting at the top of the attribute list. A real time saver when you have 60+ attributes in a single block. Anyone know the setting? Much appreciated.
RE: Editing Attributes
DBLCLKEDIT
<ON>
Hope that helps...
Rich
I do believe that this is not a setting, but a property of the new blocking/attribute structure in 2002. Any blocks I have created in 2002 have this feature, but those created in 2000 do not. Go figure!
Thanks for your help anyway!
