import of IGES file
import of IGES file
Hello all!!
I'm not able to import an IGES file created in CATIA-V5 into ANSYS-5.4 software. Can anybody tell me what might be the problem and how to rectify it.
One more thing, the extension of storing a part in IGES format is *.igs. But while saving it shows that its defifnitely an IGES file. Does this has anything to do with the problem?
Thanx in Advance
Thanx in Advance
RE: import of IGES file
Try importing IGES with defeaturing. The only disadvantage would be that one cannot perform boolean operations.
I use catia V5 as well, the only way I can get a clean transfer is in V5 options set the IGES export :Curve and surface type to "BSpline"
And in Ansys, use the defeature option.
