Passivation of Stainless Steel
Dear Friends,
While working on passivation, (65% nitric acid bath for 30 minutes), for the stainless steel finished works, i faced the following problem: some of the products changed color and turned to be like dark color on the surface.
If you can help me i would be glaful.
Regards.
Wissam Khoury.
Regards.
Wissam Khoury.
RE: Passivation of Stainless Steel
http://assist2.daps.dla.mil/quicksearch/
Another possible problem is with organics (lube/cutting oil)embedded in the surface as the result of machining. These organics combine with the nitric acid to create a powerful etchant. For further explanation of this and other passivation problems, see
http://www.finishing.com/faqs/sstpass.html
