Flow Curve for steel 1.1117 (8Mn4)
I'm looking for the flow curve for the following material:
Material number: 1.1117
Symbol: 8Mn4 ,respectively.
Anyone has any idea?
In common: where can I such flow curves get from?
Thanks for suggestions!
Best regards,
WoKu
Best regards,
WoKu
RE: Flow Curve for steel 1.1117 (8Mn4)
I do not have either of these curves for this alloy. Some places to look would be the following:
Atlas of Stress-Strain Curves from ASM International
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/ProductDisplay.cfm&ProductID=12029
Hot Working Guide: A Compendium of Processing Maps
http://www.asminternational.org/Template.cfm?Section=Search&template=Ecommerce/ProductDisplay.cfm&ProductID=10895
http://www.processingmaps.com/
http://nsmwww.eng.ohio-state.edu/FlowStressModule/Introduction/introduction.html
