Crevice corrosion
Crevice corrosion
We are using backing rings in 304L piping where it is difficult to obtain a satisfactory purge. The service fluid is borated water at 25 deg Centigrade. The piping has proven to be extremely susceptible to SCC from external chloride contamination and high residual tensile stresses. Therefore, with the high residual tensile stresses present in the pipe and at the welds, is crevice corrosion in this internal invironment (2000ppm borated water) a real risk? ASME approves the use of backing rings, but theory would suggest that crevice corrosion can occur.
RE: Crevice corrosion
While crevices are usually to be avoided, low temp. and boric acid should not be a concern IF the halogens are very low. But remember, crevices act as concentrators for them (halogens), so it all depends of the amount you have. But the boric acid is a very weak one, and does not cause problems by itself in SS especially at such low temps.
Can't you replace the OD-damaged areas? Maybe you can weld a sleeve around it, assuming it's not a long length of pipe involved.
I would have agreed with Metalguy that 304L shouldn't SCC at 25C. There are plenty of data and opinions out there that suggest that the problem only comes at higher temperatures. I'm beginning to believe that you can have SCC in austenitic stainless whenever you have pitting.
I do suggest that the remedial mechanical buffing of the surface may be mostly estheticly pleasing and may not remove the initation sites for SCC. There's good evidence that initation sites are inclusions of manganese sulfide which are surrouded by unstable austenite which not only corrodes more readily that the bulk composition, but also cracks more readily, especially at lower temperatures.
Since you can't change the microstructure at this point, you may want to induce surface residual compressive streese by shot blasting ( not steel shot).
