how to improve display resolution in drawing
I know very well how to improve the display resolution in part modelling but when I go in drawing all the arcs become flat sided and exported drawings needs reworking.
Does anybody knows how the improve display in drawing?
Thank you
robonave
Thank you
robonave
RE: how to improve display resolution in drawing
Did you ever figure this one out on your own? 'Cause I'm ahving the same problem.....
Mel
When you switch to drawing you can modify the arcs and circles smoothness through the assist-options menu clicking over the display tag just like you do for the model environment. If you have already defined some views it suffice to press the update view button at the base of the browser window.
robonave
