Mechanical Safty Switch for Carousel
I'm looking to install a mechanical safety switch to detect a tool carousel within our machine. The carousel is about 23" in diameter. I would like to park the carousel within a 1/4 turn then detect any movement with some mechanical switch that will time-out the machine.
Due to budget constraints use of optical sensors are not an option.
Do you thing I am on the right tract or should I be looking at another way of detecting the movement of the carousel?
-Caper-
RE: Mechanical Safty Switch for Carousel
How about using a proximitiy sensor and a target of adequate size on the carousel to give you the "slop" you desire.
Thanks for you comment gcaudill. We use proximity sensors on our slides.
-Caper-
