Weight bearing loads for steel beams
I manage a scrap yard and sell steel beams (typically 8w x 21lb. x 30ft. long) Customers are always asking me HOW MUCH WEIGHT CAN THIS HOLD? I cannot answer them. Is there a chart or some way to figure this out? For example if one is adding a second storey to an existing structure, and they have dimensions of the area to be added, they ask how much can this beam hold and/or how many beams would they need to span this area. I usually tell them to check with their architect or an engineer. I would like to be able to answer them here if possible. Anyone have any answers?
RE: Weight bearing loads for steel beams
26 ft unbraced length allowable total moment is 13.5 kip
The design process for a steel beam can be summarised as follows:
a) Determination of all forces and moments on critical
section
b) Selection of UB or UC
c) Classification of section
d) Check shear strength; if unsatisfactory return to (b)
e) Check bending capacity; if unsatisfactory return to (b)
f) Check deflection; if unsatisfactory return to (b)
g) Check web bearing and buckling at supports or
concentrated load; if unsatisfactory provide
web stiffener
h) Check lateral torsional buckling; if unsatisfactory
return to (b) or provide lateral restraints
i) Summarise results
As you can see due to all of the above and much more, engineers on this forum can not say how much a w8x21 or any other beam can carry.
Thank you for your addition
