Regional Construction Techniques, Materials
I am an engineer in Texas. I am about to begin a residential project on the Maine coast. In my travels around the country (mostly Midwest and Southwest) I have noticed quite a variety of construction methods and materials for residential construction. For instance some areas might build pier and beam foundations with CMU stem walls, where other areas tend to use slab on grade. Some differences are fairly obvious, such as the use of basements in northern climates such as the Chicago area. In addition it is obvious that variation in costs and availability of materials, as well as skilled laborers, can have an effect on which systems are used. I plan to talk with contractors in the vicintity of the project (Augusta, Portland) to find out what I can about the species of wood available, whether CMU or cast-in-place concrete is typically used in basement construction, etc. I would appreciate any information about regional construction (tips, books, magazines, etc.), in particular as related to this project.
RE: Regional Construction Techniques, Materials
Hope this helps, and good luck with your project!
