Inventor is unusable on files larger than 140MB
Currently, we are running Inventor 6.0 Service Pack 2 on P4 2.4 GHZ. with a Geforce 4 4200 (128 DDR on Card) and over a Gig of DDR on the board. We have other computers (1.4 GHZ. to 2.0 GHZ) with similar components that perform about the same as the P4 2.4. Our problem is that as file size increases, Inventor slows or stops responding. Our engineers have trouble working on files that are larger than 100 MB and Inventor is unusable on files that are over 140 MB. Our current service provider just informs us that AutoDesk is aware of the "memory leak" and that it will be fixed in Version 7. although, I find it hard to believe that AutoDesk would release a product that would be useable on file sizes that are typical for all users.
Can someone please help. Also, we are running these files from our local machines. Again please help.
RE: Inventor is unusable on files larger than 140MB
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
If thats not it, what are you creating?
Jeff
