rotating shaft/coupling misalignment
Is there a ASME standard that addresses the criteria for performing a shaft alignment check? If you have a flexible coupling installed, does checking the shaft alignment without un-coupling yield any useful information?
RE: rotating shaft/coupling misalignment
GET A HOLD OF THEIR REPRESENTATIVES ESPECIALLY THOSE ASSOCIATED W/ HARTBORD BOILER INSURANCE.
