differential inputs vco buffer design
Where can I find a good tutorial or application note on RF differential inputs vco buffer design?
Thanks.
Thanks.
RE: differential inputs vco buffer design
<nbucska@pcperipherals.com>
Bye
You had better go take some engineering classes.
I am new to the forum. If I read the thread correctly single ended is OK for you but not differential. I have been through this before and recommend converting SE to DE or visa versa using a balun built out of discretes. This technique works very well at 1 GHz.
