How can I split a bomtemp
I wan't to split a bomtemp with 50 parts into two bomtemps of 25 parts. The two bomtemps must be placed on two different sheets in one drawing.
RE: How can I split a bomtemp
Create two BOMs, one on each sheet, then hide the 25 items you don't want to see, in each of them.
I can give you more detailed indications, if you need.
Andrew
IMHO, this is not a good practice.  Even on multi-page assembly drawings, the BOM should be on a single page.
Gravity is a harsh mistress.
Tick,
I found this old thread and wanted to ask why this wasn't a good practice? Is there a better way to do this per "korretje's request?
Our Manufacturing group wants to use "B" size drawings (11 X 17). And an assembly with more than 30 parts gets hard to read. So we have our multi-sheet B-size drawings with the parts list of 25 items on each sheet.
Macduff
Colin Fitzpatrick
Sr. Mechanical Designer
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
SW2005 Office SP 3.1
Windows 2000 SP4.0
NIVIDA Quadro4 750 XGL
Why don't you do this:
1) RMB the cell select Split.
2) Select the second BOM
3) Edit\Cut
4) click to other sheet
5) Edit\Paste
Just tested this in SW06 and it works fine.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Ahhh..............I forgot to mention I use the Excel BOM. My bad. Can you do using the Excel BOM?
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
I think your hosed there then.
You can try and place the assembly on the second sheet put another BOM in there and do as suggested above Hide X amount on one sheet and X amount on second sheet.
You should have your company consider the SW BOM, it makes BOM use much simplier.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Yeah, I have to start playing around with the SW BOM again. The last time I worked with it, I wasn't to happy about how it saved it (.sldbomtbt). It didn't seem to save the exact changes I made when I modified the Heights and Widths of the columns and rows. Pretty much gave up with it.
Thanks for your help,
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
