is there any sources that can help
is there any sources that can help me in the field of constructing the simulink model of a ventilation unit with heat recovery wheel.
thank you!
RE: is there any sources that can help
See: DUBBEL Handbook of Mechanical Engineering, published by Springer-Verlag, Edited by W. Beitz & K.-H. Kuttner.
Chapter H - Components of Thermal Apparatus,
Section: 1.2.2 Thermodynamic Design of Regenerators, has all the equations plus a system drawing.
thank you fredb for your prompt reply and help for me.
