Circular Patterns
Circular Patterns
Catia V5R10:
How do you create a circular pattern with differing angles between instances? (i.e. Between 1 and 2=5°;Between 2 and 3=10°)
Also,
How do you 'suppress' or 'remove' an instance in a circular pattern? (i.e. A pattern of 10 instances and I want the 5th instance to be removed from the pattern)
Roger
Also,
Roger
RE: Circular Patterns
If you want to remove one (several) instance from a pattern, you just have to click the small dot in the instance. To get that instance back, just enter the definition again and click the dot.
Have fun
Eric N.
catiav5@softhome.net
THANKS!!!!!!
