Voltage controlled one shot
I'm looking for some circuit ideas to implement a voltage controlled one shot timer that would be triggered periodically.  The input would be a voltage from 1-5 Vdc and a trigger to start the timer.  The output would be a single pulse with a duration linearly dependent on the input voltage.  After the pulse the timer would be triggered again.  Any ideas?
RE: Voltage controlled one shot
I call this A Voltage Controlled Pulse Width Modulator
(VCPWM). I just think it sounds good.
This could be implemented with a small micro controller.
The micro controller must have an ADC.
If I understand correctly, then this would allow you to do things such as the following
cycle || Input Level (V)|| Output Width (ms)
 1    || 0.5            || 5
 2    || 1.5            || 15
 3    || 4.5            || 45
 4    || 2.7            || 27
and on
Let me know if you need more help
There are numerous power control ICs that perform PWM duty in relation to voltage in. TI, SG, Motorola, etc.,. select a device that has an inverting input to make it a one IC solution.
The 555 timer seems to have done the trick.  I used pin 5 as the voltage input to vary the pulse width.
Thanks all
