replaceing rubber by polyuratin
We want to replace rubber lining of acid tank in our phosphoric acid plant and useing polyuritan coating .
which group of polyuritan can we use ?
The analysis of acid is :
Cl = 4500 ppm
F = 3500 ~ 4500
P2O5 = 30 ~54 %
Thank you for your advice
psamieyan
RE: replaceing rubber by polyuratin
Since there chlorine presence Im not very sure if a polyurethane coating is the best solution. If you do not other choices try using a ether type PU minimize hidrolysis
regards
Oscar Salazar
