Vibration û measuring and analyzing
12
I’m looking for vibration tool that can measure and analyze vibration. The machine rotates by motor to 1000 RPM and has bearings, gears, shafts and belt. The machine is not fixed to ground (it’s like portable device).
Do anyone can recommend for such a tool?
Thanks,  Adavidi
RE: Vibration û measuring and analyzing
Thread384-45943 would be a good starting point.
Cheers
Greg Locock
The MAARS Model 3000 online vibration data acquisition system is designed for mobile machinery such as cranes.  Wireless technology may be used to transmit digitized data from the machine to networked vibration analysis database software. http://www.maars.com
Skip Hartman
http://www.machinerywatch.com
SignalCalc Ace which is a two-channel dynamic signal analyzer might be useful to you. Take a look at it at www.dataphysics.com
Try SmartOffice, portable with 8 channels at low cost, they have this great active graph export into Word.  www.mpiuk.co.uk
There are a few options as always price would be the major factor in your choice. C.S.I. makes a good vibration analyser with a price range from R100000 to R340000 SKF,DLI
are all options Anderson&Hurley instuments in Jhb. Supplies
CSI I am sure You would know where to find a SKF analyser.
DLI Looks good But I do not know who the supplier in South-africa is (If anybody Knows please help). There are lots of ways to monitor vibration and one must decide what you are looking for.
I hope this helps.
See http://www.lmsintl.com/ click "Analyzers" under Testing Solutions in left pane. This should take you to the LMS Pimento.
You may want to look at Thread384-39286.  Can I have a star too?
A SKF Microlog CMVA 60 is powerfull tool, you can use it but you have to make measures with sincronous time technics to separate vibrations from the ground and filter the vibration machine. Of course you must utilize a kit phase.
Hello everybody here. I´m new member and I´m happy for finally find a place were engineering is the main topic.
I´m looking for the manual of the vibration analyzer 1910 of CSI. You guys do you know were can I down load it?
Hello 325i,
Welcome to the form.
You can submit your own FAQ, and have fully answers.
Adavidi
Check 01db products (symphonie / harmony / orchestra) depending on the number of channels needed.
http://www.01dbsupport.com/
Has anyone seen a manual in English for the Reutlinger MINISELECT Frequenzspektrometer?
Thanks!
Craig
