Ideas for damping fluid borne noise?
Looking at a refrigeration loop on a vehicle with a shut off valve. When the valve opens or closes, a clunk is heard by the passengers. Considering rubber damper for mounting, any ideas for in line fitting type suppression?
RE: Ideas for damping fluid borne noise?
the second thing that comes to mind was advice my dad gave me way back when I bought my first car - an old jalopy, he said "if it makes to much noise, just turn up the radio"
best of luck,
Paul
- internal valve changes to reduce the speed of opening.
- muffler upstream of valve in high pressure line.
- resilient hose in circuit to absorb fluid energy.
The best performing and most cost effective solution was a sharp edged orifice in the high pressure line just upstream of the shut off valve.
