which language
which language
which language
which language is useful for engineering design and software deveopment like SCADA?? VB or C++ ot JAVA?
please advice
RE: which language
c++, java, delphi, kylix
I wouldn't use vb, tou will be tied down to MS windows and all the dll's
Steven van Els
SAvanEls@cq-link.sr
RE: which language
Most of the SCADA stuff that I have seen runs on an MS platform any way, so VB would be in that list as well.
Intellutions package has dll's and ocx's that can be easily integrated and used by VB to create many useful applications.
Troy Williams
fenris@hotmail.com
I am a recent Mining Engineering Graduate with an interest in Genetic Algorithms, Engineering and Computers and Programming. I also have an interest in mineral economics
RE: which language
Still the big boys in the bussiness are targetting Unix platforms, where the real processing is done.
Steven van Els
SAvanEls@cq-link.sr
RE: which language
I would be interested in hearing which packages are running on unix as I am a fan of that flavour of O/S....
Troy Williams
fenris@hotmail.com
RE: which language
We use ADVANT system from ABB on our Distributed Control System which runs on HP-UX, together with Oracle
Steven van Els
SAvanEls@cq-link.sr
RE: which language
I know that Visual Basic is used in the front-end design of most applications I have seen in the industry. Especially for HMI, MMI applications. Most large vendors (ABB, Rockwell Software, OSI PI, etc.) provide ActiveX controls that are most easily used in VB. Database programming is also much easier done in VB than C++.
RE: which language
It's a little late (just found this forum)... You might want to look at Borland's Delphi... it's an object Pascal language... fairly simple to start with and nearly as powerful as C++.
RE: which language
Forgot to add to my comment... Delphi is also available for Linux OS...
RE: which language
hi!
i thick , if u r starting from basics, then u shuold start C. its the easiest lang to start with.
u can fine many good books for that in the market, like yashwant kanitker
sandeep jindal
sandeep@rediffmail.com
