Read RS232 signal using VBA commands
Hello all, I am trying to read data coming to my computer through RS232 protocol to my 9 pin serial port from a volt meter. I have a program called Winwedge that can read the signal but I can't see a way to control that input from VBA. The signal is being sent a few times a second at 2400 baud. Any ideas?
Thank You.
Thank You.
RE: Read RS232 signal using VBA commands
TTFN
Thanks for the kick in the pants.
