Stainless Steel Welding - cosmetic
We have a stainless steel face plate that we need to weld support brackets onto the back. We have spot welded previously with CRS but the final finish was painting. Therefore, the spot weld marks and any indentations were not visible on the finished part. However, with the stainless steel face plate there will be no finish, so this marking is not acceptable. Also, we would like to avoid any extensive secondary operation, e.g. sanding or buffing, both to keep the costs down and to ensure a consistent finish. Any suggestions are appriceated.
RE: Stainless Steel Welding - cosmetic
Capacitive-discharge welding is used to attach small thermocouples and foils. You can check and see if anyone makes a big enough setup for what you need. It wouldn't mark the front face.
What type of weld joint is this? (lap, butt, tee etc.)
William Roth, PE, CWI
Thanks for the responses so far.
Passivation AMS-QQ-P-35 and ASTM A 967.
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
I am assuming that you are resistance spot welding, and that you are trying to reduce the size of the spot weld depression on the "show" side. In the automotive industry this is done by putting a small "A" electrode on the bracket side of the weld and a large flat electrode on the good side. This may take some experimentation to get the proper size "A" cap and flat cap (this depends on material thickness) once you get this set up properly you will have very little marking on the show surface.
