CO2 Corrosion Chart
CO2 Corrosion Chart
I am looking for a CO2 partial pressure vs. corrosion levels similar to the one thai I have found fot the H2S where there is a line that states the maximum pressure level to admisible corrosion...
I have looked for the Gas Processors (GPSA) books... without sucess.. Ihave no acces to NACE standars..
Thanks..
Thanks..
RE: CO2 Corrosion Chart
Can you send me the copy of the H2S Corrosion Chart, or tell me where to download it from?
I would like to know the source of H2S corrosion Chart as well.
Thanks in advance
Having found the nomograph, know that its a simplistic approach and many variables can cause it to give incorrect predictions.
You can use these sources to cross-reference the other sources that are availible.
