ASME 2/3 rule to eliminate PRV on heat exchanger?
I have a heat exchanger with 1050psi feedwater into the tubes with a 1050MAP rating. The shell is heated with 215psi Steam and has a 700 MAP. Am I required to protect the shell with a Pressure Relief Device as per ASME VIII-div.1 UG-133 (d). Heat exchangers shall be protected with a pressure relief device. I hear some type of ruling is out there for a 2/3 rule that eliminates the PRV for the shell?
