Non-linear solution
Non-linear solution
Non-linear solution
Hi all
I've developed a model in ANSYS 7.0. It's basically a series of trusses forming a cage-like structures, modelled using beam4 elements. I apply nodal forces to the structure and get approx 6mm max deflection. The analysis appears to run fine, however when I solve the analysis, ANSYS states "non-linear solution". I cannot understand why, as I have only beam4 elements in the model (although i do have Link10 elements, but these are deleted before the model is solved). No material non-linearity is included either.
Any thoughts?
Thanks in advance.
RE: Non-linear solution
Hello, Drej!
If you used Link10 elements you delete the elements but you delete the element type too ?
Best regards,
Juzz
Justin Onisoru
Researcher
Romanian Academy,
Institute of Solid Mechanics
Hi Jus,
No - I don't think so, only the elements generated are deleted I believe. Still, I think Link10 elements are "linear" elements anyway are they not, and therefore would not generate a non-linear solution?
Cheers,
-- drej --
Hello, Drej!
Please take a look at Chapter 14.10 from Ansys Theory Manual.
You will see that the solution is non-linear disregarding the non-linear or linear material you use. In fact the stiffeness matrix is not function of deformation but is function of the kind of deformation you have (it means compression-only or tension-only mode depending on your keyopt(3) setting).
Best Regards,
Juzz
Justin Onisoru
Researcher
Romanian Academy,
