Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...Just a quick note to say, "THANKS!" for these forums...The site is very well layed out and easy to use. Thanks for bringing us together - we need each other."
Geography
 Electoplating copper or tin or nickel to NiChrome
toolaholic (Mechanical)
23 Feb 01 19:38
I would like to find out what procedures are in use to apply a flash electroplated finish of copper, tin or nickel to a nickel-chromium electrical resistance alloy. I'm told that this requires extremely harsh activation chemistry. What type of chemistry?
Henry Ford said "If you need a tool and do not buy it, you will pay for it anyway"
Check Out Our Whitepaper Library. Click Here.
Helpful Member!SethN (Chemical)
21 Aug 01 16:52
toolaholic
There is a relatively new method called direct metalization which seeds a cunductive polymer to the hole to carry the electroplating current. This replaces the classical platinum seeding method.
24 Aug 01 8:48
Hi SethN
Thanks for the reference. Direct Metallization is new to me. Can you suggest a place to go for more process data? Also, you mention a hole. What did I miss? Are you referring to a site on the cathode's topology where bonding will occur?
toolaholic
24 Aug 01 11:01
toolaholic
I may have pointed you in the wrong direction, my apologies. Direct metalization is a process in printed circuit board fabrication. The technology may have other applications however. For an overview see:
http://www.electrochemicals.com/tech1.htm#dm
Seth Normyle
Process Engineer
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Electronic material engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=112
DESCRIPTION: Electronic material engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
