Tips about acid cleaning in cells from electroclorination plant
I have cells of a electroclorination plant that its cathods show  calcarium deposits wich has been causing decreas in the performance of the plant , so  my question is if , I  could clean  this cathods with  HCl 3% in solution, and , what would be  the requarments to give a succesfull cleaning
Thanks in advance
EduardoElias
RE: Tips about acid cleaning in cells from electroclorination plant
HI,
  DEPOSITE OF CALCARIUS PARTICLES ON CATHODE SURFACES IS A COMMON PROBLEM IN ANY ELECTROCHLORINATION UNIT.IF THE UNIT IS SMALLER,THE CAHODE CAN BE WASHED IN WATER(WITHOUT BRUSHING)& SUBSEQENTLY DIPPED IN HCL ACID SOLUTION CONCENTRATION OF 5% FOR ABOUT 15-20 MINUTES WITH SUBSEQUENT WATER WASH.
 FOR LARGER SYSTEMS, GENERALLY ACID SOLUTION IS RECIRCULATED
FOR ABOUT 30 MINUTES WITH SUBSEQENT WATER WASH. EFFECTIVE CLEANING TIME DEPENDS ON ACID SOLN.CONCENTRATION,HARDNESS IN BRINE ,FREQUENCY OF CLEANING IN CASE OF SEAWATER BASED SYSTEMS.WE HAVE ACHIVED VERY EFFECTIVE RESULTS WITH ABOVE
METHODOLOGY.VISIT www.iecfabchem.com FOR MORE INFO.
RAJKUMAR SURIYAPRAKASH.CHENNAI,INDIA.
Thamks for the information
Eduardo Galdos
power plant
 Ilo Peru
