Changing Property Values in VBA
I am creating a report that will have 10 different metrics on the report.  Metrics can have different options:
1. It can display VALUE (which is a percentage)
2. It can display AVERAGE DAYS
3. It can display N/A
This is what I am looking to do:
If Value is Null and Average Days <> 0 make Average Days.visible = TRUE and the others false
If Average Days is 0 and Value is Null Make NA.visible = TRUE.
The problem I am getting is that it is not reading this criteria for EACH metric so if I turn something invisible it turns that field in every metric invisible.  Can anyone help?
I would like to find a way to write code to have these three fields for every metric but to look at the results in the query to determine which field to display.
Thank you!
RE: Changing Property Values in VBA
What application? If it's Excel, you can do this using nested IF statements.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
I am using a report in Access.  I would like to write some VBA that would complete this logic when the report is opened.  Please let me know if this makes sense.
Thank you!
You may want to check out the MS Access or VBA forum at tek-tips.com. That site is much more geared towards programming.
