Automatic Draft Entity Relocation Prevention
Does anyone know of a config.pro setting or other teqnique that can be used to prevent Pro/E from repostioning draft entities (notes, dimentions, 2D geometry) when the size of the related part or assembly is changed?
Andy
RE: Automatic Draft Entity Relocation Prevention
You can use View relate options for symbols, notes and 2D entities.
Or for creating multiple draft entities, you can use draft view options from tool menu. Here you can set the view in which you will be  doing  2D drafing.
As far as size change is concerned, if your draft entities are constructed parametrically, then only they will change to new view scale.
Cheers..
Yogesh Birari
