Mechanical Desktop 6 Parts Lists
I have a large assembly that I want to include a parts list for. My assy has about 100 items. When the part list comes in, it just builds itself straight up past the drawing border.
The Question; How can I split the part list into several smaller lists on the same sheet, and still keep the item numbers incremental?
Thanks Tons
Pal
Thanks Tons
Pal
RE: Mechanical Desktop 6 Parts Lists
I believe you have to make a block of the shape you want first. I haven't done this yet, but it doesn't look to terribly difficult.
The only other thing I can think of is to make your parts list and then explode it to allow you to edit it and move portions around. Not the best option, especially if things are going to change.
Thanks to Kent
Paul
Ampartlist
right click in the filter box and select add filter
Select Custom and OK
Select Item in the first,
Less than or equal to in the second
Put in a value in the third... i.e. if you are splitting 100 rows into 4 lists, put in 25
Make sure the Custom has a check next to it.
OK to place
Run ampartlist again
Add two custom filters... first Less than or equal to 50 second greater than 25
