Want to lower HIGH horiz vibe readings !
Greetings -
- pulley
fan - -------------|||---shaft
- brg4 brg3 | belt
motor|||pulley
What could cause high horizontal readings on the motor bearings? Pulley misalignment? Belts too tight? Belts too loose? The motor bearings are sealed and not regreasable. Shaft guard prevents getting horiz readings on fan shaft bearings at this moment. What course of action is recommended to bring down the horizontal vibe?? See numbers below. Questions are welcome. Answers are too.
ODE motor bearing .75 in/sec peak at 1XRPM (3750)
DE motor bearing .57 in/sec peak at 1xRPM (3750)
- pulley
- brg4 brg3 | belt
motor|||pulley
RE: Want to lower HIGH horiz vibe readings !
Does the belt lie horizontal between sheaves, vertical between sheaves, or at an angle?
Did you check axial on the motor as well? How about fan readings? Did you leave 'em out because they were much lower?
Was there a sudden increase?
Motor RPM must be 3600 RPM. Belt is at an angle. Here are all readings at the biggest spike.
H V A
Bearing 1(RPM) .748(3750) .171(3600)
Bearing 2(RPM) .569(3750) .215(3600) .089(3750)
Bearing 3(RPM) .062(3750)
Bearing 4(RPM) .39 (3750)
New vibe program. First time readings taken on this fan.
I'm thinking fan shaft imbalance?? ---Nisqually--
i agree with electripete and would suggest check the pulley arrangement
Skip Hartman
http://www.machinerywatch.com
Is there a reason to use a pulley instead of a flexible coupling at 3600 rpm?
Anyway, I always first ask:
1. Are readings taken using a magnet mount? - If so, is hand-pressure also used - especially for horizontal readings as you won't stop the vibration, but will get more accurate readings.
2. Is a flat surface used for magnet or glued-on mounting, and are readings at bearing centerline-not at a long overhang?
We usually recommend tripping at 0.62 ips peak velocity.
I like to pass along this great on-line calculator:
http://www.wilcoxon.com/calculator.html
I like to pass along this great on-line vibration unit conversion calculator:
Thanks. I will try out the vibe calculator. I wish it could tell me how to lower the vibe on my equipment :)
Did you look at the picture? How do you use a flexible coupling with a belt driven fan? I thought that is for direct coupled fan/motors. I am new at this. Please explain. A link to a vendor website would be welcome.
I don't understand why the horizontal vibe is so high at bearing 1. The belt is attached at bearing 2 so I would expect the vibe to be higher there. But then again I am a rookie at this.
We took readings using a hand held "stinger" type probe tip. The readings are probably at bearing centerline for the fan shaft pillow block bearings but may not be so close to centerline of motor bearings. We we looking at overall vibration levels, not shock pulse although we have that information also.
Our vibe values are zero to peak. I am familiar with zero to peak, peak to peak and rms. What is ips? I thought that was iron pipe size. :)
Nisqually-rookie
See: Gardner Denver:
http://www.gardnerdenver.com/GDCorpPortal/RouteRequest?route=to&id=1333
I have to agree, to an extent, with pete. check pulley runout (taperlocks are bad for this if not properly torqued) and alignment, one question though, doesn't pulley misalignment tend to show higher in the axial direction with the dominant peak on driver being the driven and visa-versa ( just asking).
Roy Gariepy
Maintenance and Reliability Dept.
Bayer Corporation Dorlastan Fibers Div.
Goose Creek, South Carolina USA
I would very much like to understand what you are asking about pulley misalignment and the axial direction and driver versus driven but I don't. Can you please rephrase and try again? What do you mean driver being the driven and vice-versa?
-nisqually
Roy Gariepy
My suggestion would be to take phase readings. This will help to eliminate extensive time associated with the trial and error approach.
J MacK
OK then. Will the phase measurement tell me how much the sheave is wobbling, that is, rotating through an angle perpendicular to its axis of rotation? Am I making any sense?
any problems ill try to help
I would like to take a moment to mention that there probably is no right approach for all situations. Depends on your situation. (Availability of the machine for running-tests, for shutdown maintenance, availability of maintenance vs predictive manpower etc).
I don't think that going after the belt/pulley system based on what you have already is trial and error. What else (besides belt/pulley system) is going to cause highest 1x-fan rpm appearing on the motor? And since pulley alignment and belt tension cannot be adjusted independently there's not much sense in discriminating between those. Add on a pulley runout test adds another 10 minutes.
OR... you could spend another week gathering and analysing data. And how much more conclusive will your diagnosis be? And by the way is that motor still shaking at 0.75ips the whole time your analysing? Just some food for thought. As I said, there is no single right answer.
http://www.robinsonfans.com/protect/ommanual.pdf
I notice robinson doesn't differentiate between horizontal and vertical, they just use radial. I find that interesting.
(Typically on fan applications I have seen vertical bolts mounting the motor to a light metal frame/baseplate and vertical jacking bolts which move the light metal frame/baseplate with respect to the pedestal.)
I would very much like to figure out a new mounting arrangement for the millwrights if you know where I can look on the internet for mounting suggestions.
The readings are worse than last time.
4/09/03 in/sec rms overall machine vibration
3/26/03 in/sec rms (in parenthesis)
_____________
H V A
Bearing 1(RPM) .81 (.61) .23 (.13)
Bearing 2(RPM) .67 (.48) .30 (.17) .30 (.11)
Bearing 3(RPM) .31 .06 (.06)
Bearing 4(RPM) .19 .36 (.28)
