Roof Design
Roof Design
Roof Design
Please ¿Are you know design of roofs with girders rings, rafters, columns for atmosferic storage tanks API-650? ¿Which is the procedure for calculations and designs of structural roofs?
RE: Roof Design
Consult a Structural Engineer. This requires a professional qualified in this discipline and it's safer.
RE: Roof Design
My friend, you are in for a long calculation.  The requirements relating to the supported  tank roof is discussed in detail in AP!-650.  If the job is an expensive one, and you can bear the cost, you could invest in a neat piece of software called TANK by COADE (Phone 281-890-4566).  This programme will design the major components of the roof, including the ring girders, rafters and purlins.  I have used this programme, and it works.  You can also get details on their web site at WWW.COADE.COM.
If you have (or can steal, borrow, or view) a copy of the book 'Process Equipment Design' by Brownell & Yound, there is a ton of stuff in there that will help you.  The book is available at Brown Bookshop in Houston Texas for about $250, but well worth the cost.
