Datum Feature Symbol
Using ProE 2001, how do you convert the datum feature symbol to the triangle and letter box style?
Thanks in advance,
Jamie
RE: Datum Feature Symbol
I think that if I understand you correctly you want to change your datum symbol from ANSI to ISO-JIS standard?
If so, while in drawing mode click on ADVANCED=> DRAW SETUP=>
and type in gtol_datums in the dialogue box.
Hope this helps,
JW
