ABB YHMT DC Drive Printer Interface
this question relates to the mini printer that connects to the drive control pannel (YPP 109A) on ABB YHMT dc drives and I beleive others in the Tyrak/midi Range it is actually a Able Systems Mini Printer AP24 with what i think is A interface pcb Abb part no YPF 104B the printer Part No is YT290000-A
Can anyone tell me
1  what printer protocol the printer output on the control panel card uses
2 The original Able systems Part No for the printer it's self a serial no would be most helpful too
3 The output protocol of the Abb interface Card
The reason behind all this is that the able printer print quality is quite poor . If i Can obtain any of the above info i should be able to upgrade to a better quality mini printer
Finially if someone knows how to interface a standard serial/Parrallel printer to these drives please enlighten me
We use the printer to print out the fault log and also the drive parameters sometimes
Thanks for Your Time
Paul
RE: ABB YHMT DC Drive Printer Interface
Paul,
Suggest you contact Tim Gladd at ABB Drives in New Berlin, Wisconsin
I think his email is:
tim.gladd@us.abb.com
The ABB switchboard is  1-262-785-3200
and if he hasn't changed his phone...
I think his direct is  1+262-785-3363 ...
Tim has responsibilty for the DC Drive Products in North America.
Hope this helps.
jOmega
Thanks for your reply i'm currently awaiting a reply from another source if that is a deadend i try Tim
