Looking for an Frequency/Voltage converter supplier
Looking for an F/V hopefully in DIN rail mounted or modular form for industrial controls use. Was using a Dymec module on my own fabricated board which had .01% accuracy and built in variable filtering at 10KHz=10VDC (JUST DANDY!).
They no longer make this.
I really would rather not have to build my own with supply/manufacturing logistics and customer acceptance being concerns for a small production equipment manufacturing company.
RE: Looking for an Frequency/Voltage converter supplier
Frequency Input Signal Conditioner
Q478
Provides an isolated DC output signal in proportion to an input frequency
Easy field configurable input and output ranges
TouchCAL™ technology for precise calibration
Protects equipment and prevents ground loops with 1800VDC isolation
Flexible DC power: 9 to 30VDC
High density DIN rail mounting
SnapLoc™ plug-in terminals for low MTTR
ASIC technology for high reliability
Lifetime warranty
http://www.actionio.com/products/actioniq/dc/q478.html
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
http://www.thomasregister.com
and type Converters: Frequency-To-Voltage under Product or Service, which will return 40 companies to contact.
