Clear parts in assembly drawings
I would like some forum feedback on how people deal with clear parts in their assembly drawings. For example, if you have a plexiglass guard that you want show the edges of, but also show the items behind it. My best solution so far is to make a configurations in the assembly with the guard hidden / not hidden. Then I insert my drawing view using the hidden configuration, and show the guard using the Alternate Position View. The only drawback is the part comes in in phantom line font.
Any thoughts?
Any thoughts?
RE: Clear parts in assembly drawings
Learning new things ought to be outlawed. Old men like me shouldn't be learning new things, or is that old dogs?
Mr. Pickles
HTH
Ray
Also check your Line font in tools\options\document properties\line font There you can change your Line font's according to what your needing.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.3dmca.com
FAQ731-376
When in doubt, always check the help
With "component line font", you can also color the line by specifying a layer.
Drafting rules do not make distinctions between transparent parts and non-transparent parts. If something is behind a part you know to be transparent, you should use hidden lines.
If you are really determined to do this, you can attach phantom lines to the ouline of the transparent part, then hide the transparent part.
JHG
The main area where this becomes an issue is for technical manuals, where the drawing you create does not typically follow strict drafting standards. Also, your views are often isometric which really looks messy in hidden line mode.
If you can reuse your assembly drawing for an illustration in a manual, you have saved time & increased your productivity. The issue is generally that a drawing is not necessarily the same thing as an illustration.
I have used the method of converting edges of a part, then hiding it in the past. The main drawback there is if you want to attach associative balloons.
Changing the component line font works well. Why didn't I think of that? Oh well, I have to keep learning, if only to keep ahead of the forgetting.
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
