Orfice design, pressure vs flow, water
How do you do a simple approximation of the back pressure vs flow characteristics for a certain dia hole for an incompressable fluid?  I need to get 1 gallon of  water per min thru a series of holes (a sprinkler head basicly).  I have the number of holes, how do I calculate the proper dia.  I have a range of pressure available up to 70 psi.  I don't know for sure till I see the water hit the target, but I think the 15 to 25 psi range will be best for this application.
RE: Orfice design, pressure vs flow, water
A submerged circular sharp edged orifice flow may be calculated using:
Q = C*A*(2gH)^1/2
Where A = area in sq ft
      g = accel. of gravity = 32.2 ft/sec/sec
      C 0.6
      H = pressure head in feet of water
Thanks, I think I will do an try a couple experiments.  This should be invaluable to imform those efforts.
All The Best,
TTDMT
Unless you are designing a sprinkler nozzle, use this standardized formula,
               Q = K (P)^0.5
Q flow in gpm
P pressure in psi
K factor (refer to the manufacturer's catalog)
Thanks for the equation.  Can you give me a couple of manufacturers, preferably ones with the K factor data on line.
I am trying to design a sprinkler.  I have to do a rain test and the spec calls for .8gpm to fall on the specimen at a 45 degree angle.  The test specimen is good sized.  So the sprinkler head is going to sit at a 45 to gravity and measure 32" x 45" long.  I was going to put holes in the sprinkler at 3 x 3" ctr's.  From the equ RWF7437 gave me I am afraid this concept for the sprinkler is going to require rediculusly small holes.  I don't want the pressure so low the water dribles out (cause it will arc instead of hitting at 45 degrees)of the sprinkler.  I also don't want to pump much more water than required, cause it makes the test unrealisticly difficult.  Do you have ideas on how I can do this without drilling ridiculously small holes?
TTDMT
I dont design sprinkler head.  I design fire protection systems.
Well your can try "bete", "Argus", "Wormuld".
But NFPA 13 do give some example sprinklers discharge characteristics.
e.g.  Nominal Orifice size (in) / K factor:
           1/4" / 1.3 to 1.5
           5/16" / 1.8 to 2.0
           3/8" / 2.6 to 2.9
           7/16" / 4.0 to 4.4
           1/2"  / 5.3 to 5.8
           17/32" / 7.4 to 8.2
           5/8"   / 11.0 to 11.5
           3/4"   / 13.5 to 14.5
Best of luck
