Detention tank design for water
Please, give me advice how to design a detention tank for water.
RE: Detention tank design for water
Good luck.
the water is feed water for ultra filtration skids.
Although the length of the tank is enough, I have to consider 3 or more baffle for better mixing.
My question is how can I calculate the head loss for pasing over the baffles and how much thickness for baffle should i consider?
I know how to size the tank, what I am not sure about is how to calculate the pressure loss inside the tank when you have baffle inside.
I really appreciate your help.
Then they argue, flip coins and pull numbers out of thin air based on experience. It usually comes out to a couple of inches.
www.expertise-limited.co.uk/Water%20Feature%20Design.htm
Enjoy
Seán
