Assembly part becoming transparent.
All right, guys, time for what is probably a very stupid question. I was working on an assembly, when my primary part suddenly became transparent. I've tried changing its color, and checking its setting, but it's staying that way.
Any ideas?
Thanks!
Any ideas?
Thanks!
RE: Assembly part becoming transparent.
One other possibility, try editing the component properties, select color, then select remove color. The part should revert back to the same colors you see when you edit the part in a separate window.
Mr. Pickles
Thanks for the help, guys, I'm booting up now, and I'll see what happens!
Maybe this is your problem? In "System Options : Display/Selection", Is the "Assembly Transparency for in Context Edit" mode set to "Force Assembly Transparency"?
Mine is set to Opaque Assembly, which makes the non-edited parts (while in context edit) the color assigned to "Assembly, Non-Edit Parts" in the "System Properties : Color" section, and NOT transparent.
Oh, and in the "Assembly Transparency for in Context Edit" area, you can adjust the transparency slider in the "Force Assembly Transparency" setting.
Mr. Pickles
