Outdoor stairs from parking area
I am designing a parking lot expansion at the Valley of Fire State Park near Las Vegas, Nevada. There is already a visitor center with a small lot existing, but it is located on a ridge. The new lot will be at the bottom of the ridge and I must include abount 60 feet of stairs to provide access from this lower lot to the visitor center.
The existing ground consists of a reddish rock of which I am to disturb as little as possible. The existing slope of the area where the stairs are to go is fairly level for about 10 feet then it steepens to 22% for 30 feet and 43% for 10 feet with the remaining 10 feet being fairly level again. I would like suggestions on types of materials and stair types to use. I would like them to blend in with the environment if possible with maintaining a solid, fairly economical design
RE: Outdoor stairs from parking area
The wooden stairs could be founded on small concrete pesdestals which sit on the rock. The rock would have to be chipped level at those locations but that is better than drilling into the rock.
