Square Rubber cord cross-section compression
I am trying to determine how much a rubber cord of a square cross-section will compress under a known load.  I would also like to know approximately how much lateral expansion i should expect..  I ask because i am trying to design a channel for the cord to fit in to act as a seal, but the application is not for an o-ring shape.  The shape of the gasket changes according to the part being used.
Any help regarding this matter is greatly appreciated...
Thank You,
Honkerchim
RE: Square Rubber cord cross-section compression
If you can get hold of a book called 'Engineering Design with Natural Rubber' by P.B.Lindley, the answer is contained within.  If not, please reply to this saying so, then I can forward the formula's to your e-mail.  The formulas don't lend themselves to be typed here.
I have been trying to locate the book you spoke of but i am having difficulty finding it.  My email address is jrobicha@wnec.edu.  If you could send the information you have that would be great.  Thank you so much for your time.
Thanks again,
Honkerchim
I would like to recieve the email that you sent to Honkerchim.  Please send the formulas and curves for calculating the force, or presure versus deflection of rubber materials.
asher@magnevu.com
