SCADA/HMI and Direct Logic 205
Which modules are required in order to accomplish using LookoutDirect as an HMI...
H2-ECOM, D2-DCM, H2-EBC, F2-SDS-1..I am a bit confused!!
RE: SCADA/HMI and Direct Logic 205
Lookout has a list of OPC servers on the cd you have that allows you to pick most anything you want. The above list looks fine. You don't have to use ANY of the ABOVE. Lookout can talk K-SEQ and DIRECTNET both of which will connect to the cpu directly. If you what to connect ethernet, you may use some of the above.
