Projected Frontal Area from Assembly
Greetings all,
I am using a Solidworks assembly that contains some lofted and rotated parts. Is there a way to project an outline of the assembly onto an offset plane and calculate the projected frontal area? A similar question would be for an umbrella. Is there a way to find the frontal area of the umbrella from an observers plane?
Thanks for the help.
RE: Projected Frontal Area from Assembly
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
You could save some time by selecting Faces instead of Edges.
Ray Reynolds
Senior Designer
Read: FAQ731-376
If you know the furthest feature back from the "front", you could create a Section View (View : Display : Section View) along a parallel plane to the "front". Then select (click) the resulting "cut face", and get the Section Properties (Tools : Section Properties). The area will be listed of the face. If there are more than one flat faces, perhaps you have to add them up?
Ohh, well...
Mr. Pickles
Brian Lewis
The Aerospace Corporation
http://www.aero.org/
I did figure out that you can use the "Selection Filter". Set it to "Edges" and draw a box around your whole part. Then you could Control-Click on the edges you DON'T want included. Then do the Section Properties. But in your "cut a bowl in half" example, that isn't gonna work either...
It past my nap time...Can you make a drawing view of the face you want, and save it as a DXF and use AutoCAD's Area command on it? Oh my golly, did I use the dirty "A" word in here. Shoot me now folks, I'm a losing it...
Mr. Pickles
IHTH,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.3dmca.com
FAQ731-376
When in doubt, always check the help
Make a single-view temporary drawing of the part, orienting the view to the plane you wish to project. Make sure this view is scaled 1:1. Export the drawing as *.dwg or *.dxf. Reimport into a SW part file, and you will have a 2D sketch of your projection.
I tried selecting the loop to offset it and SW gives me an error that says Convert Entities Operation Failed.
I found another workaround in that if I created a block part the same height and width as my hollow part and used my part to create a cavity, the face that was left along with the area from a section view would give me the total area. I was just hoping to find a command that I could automate through VB into Excel rather than having to use these workarounds.
Thanks for the ideas though.
Brian Lewis
