Log Log Excel charts
Is it possible to have excel insert a chart that has BOTH the X axis AND the Y axis in log form?
Joe Tomei
RE: Log Log Excel charts
Sure, are you having a problem with that?  You'd need to select the scatter plot for the graph format.
TTFN
Yes I'm having trouble.
I can get a log y axis vs linear x axis but can't seem to get Log y & Log x.
How is that done?
Joe
You need to select the x-y scatterplot.
You probably selected the line chart.  The line chart only has a category x-axis, not a numerical x-axis.
TTFN
Transform your formula to logY=MlogX+logB then you can use the line chart method
No you can't.
Do it and you'll find out why it doesn't work for XY data.
Cheers
Greg Locock
Who can't?  Plotting with the XY scatter will allow for X and Y log scale.
You can't use a line chart as Rjeffery suggested, unless your data is already at logarithmcially equal intervals.
Cheers
Greg Locock
GregLocock,
Sorry.
I left off the
Sorry.
Gemtlemen,
Thanks.
I finally understand that the xy chart is fundamentally different from the line chart.
I tried the xy scatter chart, and there, it was duck soup.
Thanks for your help.
Joe Tomei
