Soybean Oil - Physical Properties
Dear friends:
I would appreciate your help in finding some physical properties of soybean oil a follows:
Boiling point
Critical temperature
Critical pressure
Critical volume
Charact. Volume
Thank you very much in advance.
RE: Soybean Oil - Physical Properties
Shmuel: I think I've seen this same thread elsewhere. True ?
"Soybeam oil" is a generic term.  There are many classifications and grades within ~ drude, degummed, refined, deodorized and hydrogenated as defined by the degree of processing and end use.
e-mail me, I can lead you to resouces
Hi guys, thanks for reply.
25362 ;
This thread also appears on heat transfer forum.
Kiwi98j ;
I would greatly appreciate your help: shmulik@boiler.co.il
