Change ext. .BAK to .DWG
I am using AutoCadd 2000i LT with Windows XP and do not know how to convert a .BAK file to a .DWG file. Can somebody please help me?
Change ext. .BAK to .DWGChange ext. .BAK to .DWG(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Change ext. .BAK to .DWG
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Thank you for the reply. I have tried renaming it, but then it renames just the file name but keeps the .BAK extension. The extension has to be changed to .DWG to open the drawing file.
Buks
Hope this helps.
Jeff Foster, PE
CE Group, Inc.
Apex, NC
In Explorer, right-click on the file name and select RENAME from the pop-up menu. Then move your cursor to the end og the file extension and drag it over the BAK to highlight it. Then keyin DWG and press enter.
In AutoCad do File/Open or Ctrl-O.
Navigate to the proper folder.
In the FileName field, type *.* and hit RETURN.
Single left click on the bak file you want.
Press F2
Press End and backspace 3 time
Type Dwg
Hit RETURN
Hit RETURN again
Keep well,
Buks.
