Network Design
Network Design
Network Design
Hi all,
I was wondering is it possible to design a communications network (with nodes connected with each other) and run some algorithms on it.
Is simulink to be used or u need the neural network toolbox.
I would apreciate any anwers
thank you
RE: Network Design
Since you obviously know nothing about Matlab, I will try to help that.  All toolboxes require Simulink to be useable.
From the limited information for what you are describing, I would suggest that you take a look at the Communications Toolbox and see how it might fit your desires.
RE: Network Design
Thank you
Tried it but cant find how to represent nodes and weighted lines to connect them in it.
As u already pointed out i am not good in matlab :( but i try to learn.
Any help is much appreciated.
Thank you again
